Calculated Relative Humidity [%]= 104.69 in the DOE Warehouse reference model. This error may be related to a Negative humidity in DOE reference model Unmet Hours solution that went over my head.
Here is a google drive link for the zip of the idf and generated files.
DOE_Warehouse
Here is a google drive link for the idf that has been significantly cleaned up with different design days.
cleaned up DOE_Warehouse
Both the err files have the same warning.
