I have received several error messages when using Option Manager to create or modify options, e.g., tried but failed to enter hourly cooling set points. Using Mac OS 10.12.6/Windows 10/Parallels to run latest BeOpt
Examples of error messages:
1.
Message: The following application error has occurred in BEopt v2.8.0.0. Please report this to the BEopt development team and restart the application.
database disk image is malformed database disk image is malformed
Stack Trace: at System.Data.SQLite.SQLite3.Reset(SQLiteStatement stmt) at System.Data.SQLite.SQLite3.Step(SQLiteStatement stmt) at System.Data.SQLite.SQLiteDataReader.NextResult() at System.Data.SQLite.SQLiteDataReader..ctor(SQLiteCommand cmd, CommandBehavior behave) at System.Data.SQLite.SQLiteCommand.ExecuteReader(CommandBehavior behavior) at System.Data.SQLite.SQLiteCommand.ExecuteReader() at NREL.BEopt.BEoptCommon.XMLMethods.ReInitialize(SQLiteCommand cmd, Int32 CategoryID) at NREL.BEopt.BEoptCommon.XMLMethods.ValidatePhysicalPropertyValues(Int32 CatID, String OptTypeXmlName, IList`1 props, String PropTypeXmlName, String PropTypeName, SQLiteCommand cmd, Boolean IsMigration) at NREL.BEopt.ObjLibCS.PhysicalProperty.set_Value(String value) at NREL.BEopt.UICS.OptionEditor.dgvProperties_CellEndEdit(Object sender, DataGridViewCellEventArgs e)
2. Message: The following application error has occurred in BEopt v2.8.0.0. Please report this to the BEopt development team and restart the application.
Stack Trace:
at System.Data.SQLite.SQLiteCommand.ExecuteNonQuery(CommandBehavior behavior)
at System.Data.SQLite.SQLiteCommand.ExecuteNonQuery()
at NREL.BEopt.BEoptCommon.DBObject.Save(SQLiteCommand cmd, IList1 saveParams, IDictionary2 IDs, IDictionary2 NewIDs, Boolean SupressDeletedRowsCheck)
at NREL.BEopt.BEoptCommon.DBProjectObject.Save(IList1 saveParams, SQLiteCommand cmd)
at NREL.BEopt.ObjLibCS.Category.Save()
at NREL.BEopt.UICS.OptionManager.SaveCategories()
at NREL.BEopt.UICS.OptionManager.OptionManager_FormClosing(Object sender, FormClosingEventArgs e)
NOTE: Tried to open Option Mgr for Cooling Set Points & modify option. 17, DR & precoolilng option
ALSO: BEOPT WINDOW FROZE WHEN I ENTERED HOURLY TEMPERATURES IN THE COOLING SCHEDULE and TRIED TO SAVE AS NEW PROJECT
