Hi.
I am using IdealLoadsAirSystem to simulate an ideal system with heating, cooling, and dehumidification (latent cooling).
Post-simulation, I can apply the COP and EER of a heat pump to the sensible heat results if I want to estimate more realistic sensible loads. How would I do a similar thing for the latent cooling component, being that a dehumidifier's efficiency is usually rated as liters of water removed per kilowatt-hour of energy consumed (i.e. energy factor)?
Is there a default energy factor value that EnergyPlus uses for the IdealLoadsAirSystem?
Thanks in advance.
