EnergyPlus/ Overhang Materials
Hello,
I am encountering a problem in EnergyPlus and I would like to ask for your support! I am using the "Shading:Overhang" command and I would like to ask if there is any way to assign a material to the overhang. I wanted to use this command so I can change the Depth in JEPlus later on. Could you, please, enlighten me?
Thank you!
Hello,
Thank you!
Hello,
Thank you!
Hello,
Thank you!
