I'm simulading a house in OpenStudio and i have a problem with the results. I add insulating in the walls for down the loss of heat, but when i run the program the inside temperature don't change, i don't understand why. Maybe I'm doning wrong '' contructions set''.
the house only has one floor and i don't understand the difference between ''exterior surface construction'' and ''ground contact surface construction'' in my case for is only one floor this is the same ?
Thank you for you help
