I am having error to run energy simulation using Honeybee interface with error message below.
Solution exception:The type initializer for 'OpenStudio.OpenStudioModelCorePINVOKE' threw an exception.
I found discussion solving this issue and tried to follow what they have tested to check the environment as below.
However, I get the error below and this is not suitable to check the environment.
Does anyone know why I get below error, while they didnt get this error in discussion?
Runtime error (MissingMemberException): 'namespace#' object attribute 'model' is read-only
import sys
import clr
sys.path.append(r'C:\openstudio-2.4.0\CSharp\openstudio')
clr.AddReferenceToFileAndPath(r'C:\openstudio-2.4.0\CSharp\openstudio\OpenStudio.dll')
import OpenStudio
model=OpenStudio.model()
print model
