I am modeling a UFAD system in IES-VE. IES has the capability of modeling several zones, so I have followed the ApacheHVAC Manual Appendix G: UFAD Systems guidance to have a common supply air plenum, a 6' high occupied zone, a stratified zone, and a common return air plenum. The guide recommends modeling heat gain through the supply plenum by raising the temperature supplied at the diffusers. My question has a few parts: 1) is this the best practice? 2) would there really be much more heat gain than in a typical overhead VAV system? Any suggestions of the best approach for splitting up the zone and the supply air temperature setpoints would be appreciated, or references that outline the approach.
