I am trying to use command line interface to run OpenStudio applying measure Set Output Table to IP units
referring to this page.
Even though I confirmed that seed file can run without error, when I try to run through command line using below batch file, seems they dont run without showing any message.
D: cd\C:\openstudio-2.4.0\bin\ "openstudio.exe" run --debug --workflow D:\Projects\Katsuya\1802_Grasshopper_Lecture\test\case4\OpenStudio\workflow.osw
I am wondering this problem is caused by missing arguments and try to find how the arguments should be specified but couldnt find.
Does anyone know how arguments should be specified for this measure? and any convention how arguments should be specified from xml file which suppose to summarize arguments for measure?
I added osw file below for your reference.
"created_at" : "20180626T033154Z",
"seed_file" : "D:/Projects/Katsuya/1802_Grasshopper_Lecture/test/case4/OpenStudio/case4.osm",
"steps" : [
"arguments" : {},
"measure_dir_name" : "Set_Output_Table_to_IP_units"
"updated_at" : "20180626T033155Z"
