For anyone familiar with the Radiance picture.cal and perforate.cal functions, I have a few questions:
- What are the acceptable file types for picture.cal?
- What other commands exist beside -s that can dimension the perforate.cal pattern? Is it possible to set the distance between objects separately from the object size?
- What is the relationship between RGB value in the colorpict and picture.cal commands and the transmissivity? It appears that the RGB value that I set in my image file determines the visible transmittance. I performed a simple box study with windows mapped with solid fills at three different RGB values (black, grey, white) and found a somewhat linear relationship between transmittance and RGB value. I would attach an image file visualizing this study but apparently I need ten points to do that...
Thanks in advance for your help and insight.
