Dear all,
I am working on a daylight simulation and currently trying to create a double insulated glass material for Radiance.
software pipeline: IGDB#optics6#window7.2#ecotect2011#grasshopper#radiance#daysim3.1
Could you, please, break down the steps on how to use optics2glazedb in glaze script
*have already found the script source.
the glazing system is: 1st layer: 4mm glass pane pvb standard 0.78mm 6mm glass pane#CL skn 174 coating 16mm argon 90% 2nd layer: 4mm glass pane
I understand your tight schedule and appreciate highly any comments that could help on this trigger.
Kind Regards from Vienna, Stella
