I'm simulating a poultry farm, and I have to put some shadows on the wall,however, I saw that i can only put shadows on the windows. is this true? or I can put a shadow on a wall?
thank you
| 1 | initial version |
thank you
I'm simulating a poultry farm, and I have to put some shadows on the wall,however, I saw that i can only put shadows on the windows. is this true? or I can put a shadow on a wall?wall?
this is my poultry farm in sketch up,but the window that you can see, is polypropylene, it is not glass. How can I assign this material to the window? or it is better not to make advantage of glass, and make polypropylene wall
thank you
| 3 | retagged |
I'm simulating a poultry farm, and I have to put some shadows on the wall,however, I saw that i can only put shadows on the windows. is this true? or I can put a shadow on a wall? this is my poultry farm in sketch up,but the window that you can see, is polypropylene, it is not glass. How can I assign this material to the window? or it is better not to make advantage of glass, and make polypropylene wall
