What software can generate COMNET Standard Reports?
What software can generate the COMNET Standard Reports in either PDF or XML format? I would specifically like to use OpenStudio, but am generally interested to learn what other tools have this capability.
I know that OpenStudio is able to generate a valid COMNET XML, with the XcelEDAReportingandQAQC measure and PAT's EDAPT Export, although it's not documented anywhere. Are there other ways to generate a COMNET XML (or JSON) using OpenStudio?
I know that OpenStudio is able to generate a valid COMNET XML, XML with the XcelEDAReportingandQAQC measure and PAT's EDAPT Export, although it's not documented anywhere. Are there other ways to generate a COMNET XML (or JSON) using OpenStudio?
I know that OpenStudio is able to generate a valid COMNET XML with the XcelEDAReportingandQAQC measure and PAT's EDAPT Export, although it's not documented anywhere. Are there other ways to generate a COMNET XML (or JSON) using OpenStudio?
UPDATE:
After a bit of research, the COMNET XML schema is identical to NREL's Energy Design Assistance XML Schema, i.e. COMNET's schema was copied directly from NREL's.
UPDATE:
UPDATE: After a bit of research, the COMNET XML schema is identical to NREL's Energy Design Assistance XML Schema, i.e. COMNET's schema was copied directly from NREL's.
UPDATE: __UPDATE__
__UPDATE__UPDATE
UPDATE
