6/18/2018 11:21 PM: 01.xml: Warning: The building has no cooling equipment but a cooling setpoint is specified; the simulation will proceed without a cooling system. 6/18/2018 11:21 PM: 01.xml: Error: * Severe * Kiva: Solution did not converge after 0 iterations. The final residual was: (-nan(ind)). 6/18/2018 11:21 PM: 01.xml: Error: * Fatal * Kiva: Errors discovered, program terminates. 6/18/2018 11:21 PM: 04.xml: Warning: The building has no cooling equipment but a cooling setpoint is specified; the simulation will proceed without a cooling system. 6/18/2018 11:21 PM: 03.xml: Error: * Severe * DualSetPointWithDeadBand: Unanticipated combination of heating and cooling loads - report to EnergyPlus Development Team 6/18/2018 11:21 PM: 03.xml: Error: * ~~~ * occurs in Zone=FINISHEDBASEMENT_1 During Warmup & Sizing, Environment=PLANT DD, at Simulation time=01/01 00:00 - 00:10 6/18/2018 11:21 PM: 03.xml: Error: * ~~~ * LoadToHeatingSetPoint=NAN, LoadToCoolingSetPoint=NAN 6/18/2018 11:21 PM: 03.xml: Error: * ~~~ * Zone Heating Set-point=20.00 6/18/2018 11:21 PM: 03.xml: Error: * ~~~ * Zone Cooling Set-point=25.56 6/18/2018 11:21 PM: 03.xml: Error: * ~~~ * Zone TempDepZnLd=592.46 6/18/2018 11:21 PM: 03.xml: Error: * ~~~ * Zone TempIndZnLd=NAN 6/18/2018 11:21 PM: 03.xml: Error: * ~~~ * Zone ThermostatSetPoint=0.00 6/18/2018 11:21 PM: 03.xml: Error: * Fatal * Program terminates due to above conditions. 6/18/2018 11:21 PM: 04.xml: Error: * Severe * Kiva: Solution did not converge after 0 iterations. The final residual was: (-nan(ind)). 6/18/2018 11:21 PM: 04.xml: Error: * Fatal * Kiva: Errors discovered, program terminates. 6/18/2018 11:21 PM: 02.xml: Error: * Severe * DualSetPointWithDeadBand: Unanticipated combination of heating and cooling loads - report to EnergyPlus Development Team 6/18/2018 11:21 PM: 02.xml: Error: * ~~~ * occurs in Zone=FINISHEDBASEMENT_1 During Warmup & Sizing, Environment=PLANT DD, at Simulation time=01/01 00:00 - 00:10 6/18/2018 11:21 PM: 02.xml: Error: * ~~~ * LoadToHeatingSetPoint=NAN, LoadToCoolingSetPoint=NAN 6/18/2018 11:21 PM: 02.xml: Error: * ~~~ * Zone Heating Set-point=20.00 6/18/2018 11:21 PM: 02.xml: Error: * ~~~ * Zone Cooling Set-point=25.56 6/18/2018 11:21 PM: 02.xml: Error: * ~~~ * Zone TempDepZnLd=583.36 6/18/2018 11:21 PM: 02.xml: Error: * ~~~ * Zone TempIndZnLd=NAN 6/18/2018 11:21 PM: 02.xml: Error: * ~~~ * Zone ThermostatSetPoint=0.00 6/18/2018 11:21 PM: 02.xml: Error: * Fatal * Program terminates due to above conditions. 6/18/2018 11:21 PM: 05.xml: Error: * Severe * DualSetPointWithDeadBand: Unanticipated combination of heating and cooling loads - report to EnergyPlus Development Team 6/18/2018 11:21 PM: 05.xml: Error: * ~~~ * occurs in Zone=FINISHEDBASEMENT_1 During Warmup & Sizing, Environment=PLANT DD, at Simulation time=01/01 00:00 - 00:10 6/18/2018 11:21 PM: 05.xml: Error: * ~~~ * LoadToHeatingSetPoint=NAN, LoadToCoolingSetPoint=NAN 6/18/2018 11:21 PM: 05.xml: Error: * ~~~ * Zone Heating Set-point=18.33 6/18/2018 11:21 PM: 05.xml: Error: * ~~~ * Zone Cooling Set-point=24.44 6/18/2018 11:21 PM: 05.xml: Error: * ~~~ * Zone TempDepZnLd=693.31 6/18/2018 11:21 PM: 05.xml: Error: * ~~~ * Zone TempIndZnLd=NAN 6/18/2018 11:21 PM: 05.xml: Error: * ~~~ * Zone ThermostatSetPoint=0.00 6/18/2018 11:21 PM: 05.xml: Error: * Fatal * Program terminates due to above condition
