Measure and idf run successfully in Openstudio, but not PAT
I am trying to setup 11 building models to simulate in each of 7 climate zones and am having a bit of trouble with the Parametric Analysis Tool. The measure I'm using is an energyplus measure, which deletes everything in the input osm/idf and adds every object in an external idf file. This is so we could use our current idf files without having to translate them into osm files.
The idf runs with ep-launch, and the measure and idf run in Openstudio, but the PAT doesn't run successfully.
The error is "completed Fail" in PAT, but not much else. I looked through the files in the PAT directory and found the following error message at the bottom of this file.
C:\Users\Mitchal Dichter\Desktop\automater\temp_data\analysis_598964f5-d857-4411-87b9-013f1a7abaef\data_point_99751e0c-75fb-42fa-9dc5-cbe84b9ff489\run
[15:32:49.623487 INFO] Setting argument value 'source_idf_path' to 'C:\Users\Mitchal Dichter\Desktop\IDF baseline cases\DOE_FullServiceRestaurant\in.idf'
[15:32:49.623487 DEBUG] Calling measure.run for 'load_base_model'
[15:32:49.624488 INFO] The initial IDF file had 24 objects.
[15:32:49.625488 INFO] The emptied IDF file has 0 objects.
[15:32:49.878361 INFO] The final IDF file had 745 objects.
[15:32:49.878361 DEBUG] Finished measure.run for 'load_base_model'
[15:32:49.990279 DEBUG] Running of measure 'load_base_model' completed. Post-processing measure output
[15:32:49.990279 INFO] Moving to the next workflow step.
[15:32:49.990279 INFO] Finished applying EnergyPlus measures.
[15:32:49.990279 DEBUG] Communicating measure output attributes to the output adapter
[15:32:50.100214 ERROR] Found error in state 'ep_measures' with message ["\"\\xB0\" from ASCII-8BIT to UTF-8:C:/openstudio-2.5.0/pat/OpenStudio-server/gems/gems/openstudio-workflow-1.3.2/lib/openstudio/workflow/util/model.rb:94:in  ......... omitted text ............... `call'\nC:/openstudio-2.5.0/pat/OpenStudio-server/gems/gems/daemons-1.2.6/lib/daemons/cmdline.rb:92:in `catch_exceptions'\nC:/openstudio-2.5.0/pat/OpenStudio-server/gems/gems/daemons-1.2.6/lib/daemons.rb:196:in `run_proc'\nC:/openstudio-2.5.0/pat/OpenStudio-server/gems/gems/delayed_job-4.1.4/lib/delayed/command.rb:123:in `run_process'\nC:/openstudio-2.5.0/pat/OpenStudio-server/gems/gems/delayed_job-4.1.4/lib/delayed/command.rb:98:in `daemonize'\nbin/delayed_job:6:in `<main>'"]}
[15:32:50.100214 INFO] Finished workflow - communicating results and zipping files
[15:32:50.275114 INFO] Workflow complete
Here is a google drive link of all the relevant files.
Any idea what could be wrong? My only idea is the external IDF loaded is incompatible with whatever PAT is using to simulate, but I couldn't find a not empty idf file within the PAT directory.
