I am using the Inject IDF Ojbects (correct spelling) Energyplus measure from the BCL and it doesn't add any objects.
The starting osm file is a freshly created osm, so blank except for whatever Openstudio puts in a new file.
My input parameter for the measure is "C:\Users\Mitchal Dichter\Desktop\find_me.idf" without the quotes.
The relevant code is
# report initial condtion
runner.registerInitialCondition("The initial IDF file had #{workspace.objects.size} objects.")
# load the idf file
if source_idf_path == ""
runner.registerError("No Source IDF File Path was Entered.")
return false
elsif not File.exists?(source_idf_path)
runner.registerError("File #{source_idf_path} does not exist.")
return false
elsif OpenStudio::IdfFile::load(OpenStudio::Path.new(source_idf_path)).empty?
runner.registerError("Cannot load #{source_idf_path}")
return false
else
# use OpenStudio::IdfFile instead of OpenStudio::Workspace so links to objects not in IDF will be maintained
source_idf = OpenStudio::IdfFile::load(OpenStudio::Path.new(source_idf_path)).get
end
# add everything from the file
workspace.addObjects(source_idf.objects)
# report final condition
runner.registerFinalCondition("The final IDF file had #{workspace.objects.size} objects.")
and the output from Run Simulation in Energyplus is
Applying InjectIDFOjbects
Result: Success
Initial Condition: The initial IDF file had 24 objects.
Final Condition: The final IDF file had 24 objects.
Starting Simulation.
The two important lines are
The code gets past the error checking, so the idf file exists, is not empty, and loaded successfully, but workspace.addObjects(source_idf.objects) doesn't add any objects.
Is this the most up to date syntax? I noticed a couple different ways to get an idf file and for addObjects in UnmetHours.
I also noticed this line in the file:
class InjectIDFOjbects < OpenStudio::Ruleset::WorkspaceUserScript
I there anything special I should do to use a WorkspaceUserScript?
