Hi there! I created an open studio model using sketchup. I saved as osm and as skp. I reopened them and I can't see the geometry. I only see the points of the spaces I created. In Inspector everything is listed, every space, every surface. Moreover,if I open the skp file, a warning says "Removing previously linked OpenStudio content. Open OpenStudio model at 'C:/Users/...osm' to restore content". Can somebody help me? I don't necessary need to recover the work I did, but I want to be sure that if I do the model again I won't lose it! Did I make a mistake when I saved the files maybe?
