Combination of Simulations in Energyplus
I want to perform different permutations and combinations of different parameters in energyplus Unfortunately,each new object in Parametric:SetValueForRun every value is in correspondence to the run E.g.: if Run 3 is going on,Object 1 will use value 3; Object 2 will use value 3 and so on Is it possible in anyway to set that until object 1 values have not been finished, the values from other objects will be constant like a loop in a loop E.g: obj 1 has 10 values but object 2 has 5 Therefore total runs are 50 and on run 11; 10th value is chosen from object 1 and and 2nd value from object 2 is used Thus allowing simulation of all possible combinations
