I would live to know, what is de different between these two colums... surface name and outside boundary condition object?? the same name of the surface must appear in both columns??
thank you
|   | 1 |  initial version  |
thank you
|   | 2 |  retagged  |
thank you
thank you
I would live like to know, know what is de different the difference between these two colums... columns: surface name and outside boundary condition object?? the object? The same name of the surface must appear in both columns??
thank you columns?
|   | 5 |  retagged  |
I would like to know what is the difference between these two columns: surface name and outside boundary condition object? The same name of the surface must appear in both columns?
