Hi guys, I'm trying a single zone HVAC setting, but as I shown in the topic when assigning PTAC system. Somehow it shows the fatal issue, something like Field〔control zone name〕is required but was blank...
* Severe * IP: IDF line~2475 Error detected in Object=SETPOINTMANAGER:SINGLEZONE:REHEAT, name=SETPOINT MANAGER SINGLE ZONE REHEAT 3 * ~~~ * Field [Zone Inlet Node Name] is required but was blank *** IDF Context for following error/warning message: *** Note -- lines truncated at 300 characters, if necessary... *** 2725 SetpointManager:SingleZone:Reheat, *** indicated Name=Setpoint Manager Single Zone Reheat 4 *** Only last 5 lines before error line shown..... *** 2726 Setpoint Manager Single Zone Reheat 4, !- Name *** 2727 Temperature, !- Control Variable *** 2728 -99, !- Minimum Supply Air Temperature {C} *** 2729 99, !- Maximum Supply Air Temperature {C} *** 2730 , !- Control Zone Name
Hope someone could kindly help. Thanks!
(/upfiles/15275897401352849.jpg)
