Hi guys, I'm trying to incorporate a heat recovery chiller between my condensing loop and my heating loop instead of doing free cooling with economizer control. I'm using Openstudio version 2.5.1, and have followed the Central Heat Pump System object has proposed by Julien Marrec in this fix.
I think this method is pretty new, I did not find example to guide me in the assembly of this measure and the control that is adequate.
This is how I placed the Central heat pump system object in my three loops:
It would be appreciated to have a file or screen shots of the proper assembly and example of control that could be used.
Thanks !
