Old HVAC systems settings?
This is in connection with my other question at: link text
Doing a research project on tall buildings in hot climates, I am going to simulate two HVAC systems to represent old and current conditions. The research is not focused on HVAC systems but defining and simulating two "conventional" systems are inevitable: one for the past (decades ago, when windows with single pane glass where common) and one for present time.
For present scenario I'm using FCU+DOAS...
My question here is about the past scenario: Which HCAC systems where most common for tall buildings in the past? Any information about setting related parameters would also be helpful e.g. cooling COP, airsideeconomizer, thermostats common values, min and max indoor humidity, etc.
Thanks
Software: Grasshopper/Honeybee/OpenStudio/EnergyPlus
My question here is about the past scenario: Which HCAC HVAC systems where most common for tall buildings in the past? Any information about setting related parameters would also be helpful e.g. cooling COP, airsideeconomizer, thermostats common values, min and max indoor humidity, etc.
Thanks
Doing a research project on tall buildings in hot climates, climates (tropical desert e.g. Dubai), I am going to simulate two HVAC systems to represent old and current conditions. The research is not focused on HVAC systems but defining and simulating two "conventional" systems are inevitable: one for the past (decades ago, when windows with single pane glass where common) and one for present time.
My question here is about the past scenario: Which HVAC systems where most common for tall buildings in the past? Any information about setting related parameters would also be helpful e.g. cooling COP, airsideeconomizer, thermostats common values, min and max indoor humidity, etc.
Thanks
This is in connection with my other question at: link texthere
Doing a research project on tall buildings in hot climates (tropical desert e.g. Dubai), I am going to simulate two HVAC systems to represent old and current conditions. The research is not focused on HVAC systems but defining and simulating two "conventional" systems are inevitable: one for the past (decades ago, when windows with single pane glass where common) and one for present time.
Thanks
This is in connection with my other question here
Thanks
Old Settings of old conventional HVAC systems settings?for tall buildings in hot climates
Thanks
Settings of old conventional HVAC systems for tall buildings in hot climates
Thanks
Settings of old conventional HVAC systems for (for tall buildings in hot climatesclimates)
Thanks
