I am using OpenStudio 2.5.0 for a project. I selected some variables to view, and successfully ran the osm file. I then changed the specific variables and frequencies of report. Ran the osm file and in viewing the variable output file in csv format, I noticed that the variables I had deleted were still present, one of which was mistakenly selected as time step. I opened up the OpenStudio generated idf file and discovered that the variables I had deleted were still in the idf file. I then manually deleted the offending variables and ran the idf file in EnergyPlus. Why are they not clearing in OpenStudio? Actually I have noticed this happening when changing the parameters in an outdoor air object.
