Dear Team,
Could you please help me in sort out the error of this particular file?
Problem statement:
I am modeling infiltration rate through a block using energy plus......It is an air conditioned space. I have supply air flow rate and return air flow rate. through that I am finding out the static pressure inside the room....
then, because of outside pressure, there will be pressure difference between inside and outside and hence infiltration is prone to occur through envelope cracks....this is my problem statement
in this aspect, I faced a problem regarding Air flow network distribution model. please explain me about the errors
https://drive.google.com/file/d/12dkrARz9KZI7xGS1IysmPqGDwyy1iDra/view?usp=sharing
please have a look into this.....
These are the errors...
* Severe * ValidateDistributionSystem: COOLING COIL AIR OUTLET NODE is not defined as an AirflowNetwork:Distribution:Node object. * Severe * ValidateDistributionSystem: MIXED AIR NODE is not defined as an AirflowNetwork:Distribution:Node object. * Fatal * ValidateDistributionSystem: Program terminates for preceding reason(s). ...Summary of Errors that led to program termination: ..... Reference severe error count=2 ..... Last severe error=ValidateDistributionSystem: MIXED AIR NODE is not defined as an AirflowNetwork:Distribution:Node object.
Eventhough I defined Cooling COil Air Outlet Node and Mixed Air Node...Why am I still getting the same error...
please someone help to fix this error...and let me know your opinion on my methodology as well
