Dear Unmet team,
Running a simulation for a datacenter project, in a 200 M2 IT room with 160 Kw IT load, something funny thing happens:
1- If the IT load is low (10 Kw) the simulation runs well 2- If the IT loads is high (160 Kw) the simulation fails, warnings and severe are presents.
Warning ** Inside surface heat balance did not converge with Max Temp Difference"
and
severe the surface temperature is out of bounds,
some body knows how to solve it?
Thanks
