Hello Unmet Hours,
I am currently running OS 2.5.0 and PAT V2.
I am trying to change the WWR of this facade (See attached) using the "Set WWR by Facade" but for some reason it isnt changing to anything larger than it already is. I have a strong feeling that this is due to the positioning of the windows being different. Does PAT need uniform window position to run this measure?
If so, how can I change my model so that I can get this measure to work on the facade?
Thanks.
