Lately I upgraded from OS 2.4.0 to OS 2.5.0 which uses E+ 8.9.0 running a model which went smoothly in OS 2.4.0 I get the following severe warning:
** Severe ** Construction="BASEMENT SOUTH WALL", constructions referenced by surfaces with a
** ~~~ ** "Foundation" Outside Boundary Condition must use only regular material objects
** ~~~ ** Material="RAINSCREEN AIR GAP- 3CM", is not a regular material object
** Fatal ** GetSurfaceData: Errors discovered, program terminates.
Basement South Wall is as follows:
OS:Construction,
{376dd82a-b32b-4dc1-af27-1a32b8c28f40}, !- Handle
Basement South wall, !- Name
{28f9cfcc-fbd2-44f4-95c8-bffd390b6c5d}, !- Surface Rendering Name
{2bc24013-4530-4b16-a9ab-31eaa2affbd9}, !- Layer 1
{5129f43c-7dfb-4ee1-8ddf-2a8c97e14f70}, !- Layer 2
{6583688a-8955-4df4-880e-d0b20b2f2fba}, !- Layer 3
{da94b23a-5357-4df0-b1bc-31f4ab4f813f}; !- Layer 4
OS:Material,
{2bc24013-4530-4b16-a9ab-31eaa2affbd9}, !- Handle
aislamiento-sate-weber-weber-therm-placa-xps-50-0-050-m-r-1-5-m2k-w, ! Name
MediumRough, ! Roughness
0.05, ! Thickness {m}
0.034, ! Conductivity {W/m-K}
30.0, ! Density {kg/m3}
800.0; ! Specific Heat {J/kg-K}
OS:StandardsInformation:Material,
{35ded093-f0c3-44d9-a426-58782d2f21e2}, !- Handle
{2bc24013-4530-4b16-a9ab-31eaa2affbd9}; !- Material Name
OS:Material,
{5129f43c-7dfb-4ee1-8ddf-2a8c97e14f70}, !- Handle
Basment Poured Concrete wall, ! Name
0.2, ! Thickness {m}
1.63, ! Conductivity {W/m-K}
2400, ! Density {kg/m3}
840; ! Specific Heat {J/kg-K}
{8599b563-b3c8-4ea8-999a-5c5097eb1d18}, !- Handle
{5129f43c-7dfb-4ee1-8ddf-2a8c97e14f70}, !- Material Name
, !- Material Standard
, !- Material Standard Source
Concrete, !- Standards Category
, !- Standards Identifier
, !- Composite Framing Material
, !- Composite Framing Configuration
, !- Composite Framing Depth
, !- Composite Framing Size
; !- Composite Cavity Insulation
OS:Material:AirGap,
{6583688a-8955-4df4-880e-d0b20b2f2fba}, !- Handle
RainScreen Air Gap- 3cm, !- Name
1; !- Thermal Resistance {m2-K/W}
{44d277be-76de-46d7-80a1-6da64dbb031a}, !- Handle
{6583688a-8955-4df4-880e-d0b20b2f2fba}; !- Material Name
OS:Material,
{da94b23a-5357-4df0-b1bc-31f4ab4f813f}, !- Handle
Single Gypsum Board, !- Name
Smooth, !- Roughness
0.0127, !- Thickness {m}
0.21, !- Conductivity {W/m-K}
784.9, !- Density {kg/m3}
830.000000000001, !- Specific Heat {J/kg-K}
0.9, !- Thermal Absorptance
0.4, !- Solar Absorptance
0.4; !- Visible Absorptance
{c53a4dce-f4f2-4062-9a94-0a22dfd5bdb8}, !- Handle
{da94b23a-5357-4df0-b1bc-31f4ab4f813f}; !- Material Name
Any ideas?
