When I try the run OS model which used to run straight in OS 2.4.0 in OS 2.5.0 I get the E+ warnings:
** Warning ** ProcessScheduleInput: Schedule:Day:Interval="2LLO TUESDAY", Values are outside of range for Schedule Type Limits Name=FRACTIONAL
And finally I get the E+ severe :
** Severe ** ProcessScheduleInput: Schedule="2ND LIVING LIGHT USAGE" has values outside its Schedule Type (FRACTIONAL) range
** ~~~ ** Minimum should be >=0.000 and Maximum should be <=1.000
The following are relevant lines from the in.idf file:
ScheduleTypeLimits,
Fractional, !- Name
0, !- Lower Limit Value {BasedOnField A3}
1, !- Upper Limit Value {BasedOnField A3}
Continuous; !- Numeric Type
Schedule:Day:Interval,
2LLO Tuesday, !- Name
Fractional, !- Schedule Type Limits Name
Linear, !- Interpolate to Timestep
06:00, !- Time 1 {hh:mm}
0, !- Value Until Time 1
07:15, !- Time 2 {hh:mm}
1, !- Value Until Time 2
16:15, !- Time 3 {hh:mm}
0, !- Value Until Time 3
18:15, !- Time 4 {hh:mm}
1, !- Value Until Time 4
24:00, !- Time 5 {hh:mm}
0; !- Value Until Time 5
The errors are eliminated when Average is replaced with Linear in interpolate to Timestep. Am I doing something wrong?
