After downloading the "add Output DIagnostics" I am still getting this output in my eplusout.err file:
* Warning * GetSurfaceData: There are 4 coincident/collinear vertices; These have been deleted unless the deletion would bring the number of surface sides < 3. * ~~~ * For explicit details on each problem surface, use Output:Diagnostics,DisplayExtraWarnings; * Severe * GetSurfaceData: There are 1 degenerate surfaces; Degenerate surfaces are those with number of sides < 3. * ~~~ * These surfaces should be deleted. * ~~~ * For explicit details on each problem surface, use Output:Diagnostics,DisplayExtraWarnings; * Fatal * GetSurfaceData: Errors discovered, program terminates. ...Summary of Errors that led to program termination:
