I use this example from eppy documentation to run a simulation:
iddfile = "/usr/local/EnergyPlus-8-9-0/Energy+.idd"
IDF.setiddname(iddfile)
idfname = "/usr/local/EnergyPlus-8-9-0/ExampleFiles/BasicsFiles/Exercise1A.idf"
epwfile = "/usr/local/EnergyPlus-8-9-0/WeatherData/USA_IL_Chicago-OHare.Intl.AP.725300_TMY3.epw"
idf = IDF(idfname, epwfile)
idf.run()
The document says that I should get an output like:
Processing Data Dictionary
Processing Input File
Initializing Simulation
Reporting Surfaces
Beginning Primary Simulation
Initializing New Environment Parameters
Warming up {1}
Warming up {2}
Warming up {3}
Warming up {4}
Warming up {5}
Warming up {6}
Starting Simulation at 07/21 for CHICAGO_IL_USA COOLING .4% CONDITIONS DB=>MWB
Warming up {1}
Warming up {2}
Warming up {3}
Warming up {4}
Warming up {5}
Warming up {6}
Starting Simulation at 01/21 for CHICAGO_IL_USA HEATING 99.6% CONDITIONS
Writing final SQL reports
EnergyPlus Run Time=00hr 00min 0.24sec
,however, I get nothing in the python. Only I see these new files in the directory that I run the python script:
eplusout.audit eplusout.bnd eplusout.dxf eplusout.eio eplusout.end eplusout.err eplusout.eso eplusout.mdd eplusout.mtd eplusout.mtr eplusout.rdd eplusout.shd. These files include a lot different outputs, but the point is that I could not find any standard way of reading these files through eppy. In the documentation, there is a section Reading outputs from E+ which explains how one can use htmlreader to extract the output of E+ simulations. However, there is no html file among the generated files. I can read those files manually through f.read() function in python, but I thought probably I am missing a point and there should a way to get the output of the idf.run() directly in python.
I would appreciate any help and comment.
Thanks, Afshin
