Does anyone know which heat pumps (manufacturer & model) the BEopt default models are based on? I'm looking for the air source heat pump: SEER 22, and Mini-split heat pumps: E) & F)(ducted). The mini-split models are apparently derived from the NEEP ccASHP database [http://www.neep.org/initiatives/high-efficiency-products/emerging-technologies/ashp/cold-climate-air-source-heat-pump] and I'm trying to figure out how the BEopt inputs were derived so I can do the same for other models.
(I apologize because I've asked this question before in the BEopt forum, but the forum has just been migrated to Unmet hours and apparently all previous threads have disappeared forever)
