Hi,
I am trying to use MPC algorithms with an Openstudio model.
The procedure propsed in the paper "Building energy model reduction for model predictive control using OpenStudio" by Wesley Cole (http://ieeexplore.ieee.org/document/6579878/) seems to be a good fit.
Unfortunately I am unable to find the mentioned script (in section IV "Model reduction Methodology") with which I would be able to reduce the model.
Does anyone know where I can find this script? Or is there another script I could use performing a similar task?
Besides that I also found that there exists some other software like BCVTB with which, as far as I can see, one could perform MPC without model reduction. Has anyone expierence with such software and knows how computationally that is?
Thanks for your help!
