Dear all,
I would appreciate it if you let me know how I can model the air distribution of a room in which the cold air is supplied to the upper node? I succeeded only when the mixing mode was selected. When I selected, for instance, 3-node model, the results were not meaningful. Apparently, the 3-node model is applicable for displacement ventilation, in which the cold air is supplied to the lowest node.
Thanks
