I am trying to run a simulation for a residential facility using Parametric Analysis Tool. When the HVAC measures are turned ON, the simulation fails whereas it runs successfully when the HVAC measures are turned OFF. Obviously HVAC measures are very important to run the simulation and I would like to run the simulation with the HVAC measures ON. I was wondering if anyone of you has had such a problem and fixed it or know a method to fix this bug.
