Hi I have had difficulty getting the residential library installed with OpenStudio 2.4.3. I found that I had to edit the rakefile to add "require 'OpenStudio'" to get it to add the residential measures into OS. After this small change, everything seem to be added in except for a warning "Warning: There are 2 measures missing in 'workflows/measure-info.json': ResidentialGeometryFromFloorspaceJS,ResidentialPhotovoltaics". Is this significant and is there a work around?
Cheers
