I am using PAT V2 for OS 2.4. I have a seed model that runs successfully in openstudio alone, a weather file, and I have added a few measures, only one of which I change for my design alternatives. One of the measures I added is the Openstudio Reporting measure, where all of the arguments are set to true. I have created at least measure one option for each measure. All of my design alternatives have a measure option selection for each measure.
When I run the entire workflow I get a status bar which says "Analysis Completed" and for each of the design alternatives the status is "completed Fail" and there are 0 warnings and 0 errors. When I click on the reports tab, under Summary Table it says "The OpenStudio Results measure was not included in Alternative #, cannot show results".
I don't understand why this is happening since I have added the OpenStudio Results measure (from the BCL) and I have created a measure option which sets everything to true and I assign that measure option for every design alternative.
