Hi all,
When I am modleing Radiant Cooling system, I wish to see the effect of change in diameter and length of Hydronic tube. So I did change in the section of "Hydronic Tube inside Dia" but the effect of the number is not seen in the results of Radiant Cooling capacity.
any other way to alter the Hydronic Tube specifications and see the effect on Cooling capacity?
