Dear All I am using type 66a to link an EES code into my project. The code works when I run in EES alone. But when I am going to link it into TRNSYS using type 66a, I get following error: "Threre are 104 equations and 113 variables with 5 set with import. The problem is under specified and can not be solved" What is the problem?! Thank you
