Dear all,
I succesfully built an Openstudio model using the plugin en calculated the district heating and cooling consumption in the openstudio application.
To check if these results can be trusted i am trying to visualize the different heat flows at any given hour.
I am trying, but can't seem to find the right output parameters to use for getting this information.
Hopefully someone can help me, what are the names of the output parameters i need to use to get:
- Transmission heat gains/losses
- Ventilation heat gains/losses
- Solar heat gains
- Internal heat gains
- Infiltration heat losses
(For the entire building enveloppe, so the opaque surfaces - walls, roofs, floors - and the windows)
Thank you in advance.
