OpenStudio now uses DView directly for data visualization instead of ResultsViewer. However, while trying to open data dview takes several minutes (sometimes 15 or more) just to open a small output file. Are there any fixes I can do to that will make this process faster?
In the meantime, I will likely need to use another results viewer because this is too slow.
