When I define the ground surface temperature based on the handbook that 2C less than the indoor temperature, the thickness showed a positive correlation with Heating energy comsumption, and heat conductivity coefficient showed a negative correlation with heating energy in a severe cold region. It seems that the ground has a heating effect. That is abnormal, so dose anyone has encontered the some problem or how to change it.
