Hi all,
I am trying to create the idf objects circled in the image below using the OpenStudio SDK however I am having a lot of trouble making sense of the SDK
For example there is the Generator_PhotovoltaicFields class reference seen here
I assume that this is this the class that I should use to add a photovoltaic generator to the model? If is, how do I use it?
Any example code or pointers on how to decipher the SDK would be most appreciated.
