Using Radiance to generate solar surface gain schedules
Hi all, From my understanding I need values for absorbed radiation in both opaque ( using the SurfaceProperty:SolarIncidentInside object) and transparent elements (using the ComplexFenestrationProperty:SolarAbsorbedLayers object) .Although it is straightforward to calculate solar gains on the inside face of walls, ceiling and floor I am a bit confused about how to calculate absorbed radiation on each layer of the glazing system since we model windows as single surface in Radiance.
Regards, Kostas
