Here is metioned that the total static pressure has to be used for the Fan Pressure Rise parameter in EnergyPlus.
Can someone explain why the total pressure (= total static pressure + dynamic pressure) should not be used? Thank you in advance!
| 1 | initial version |
| 2 | retagged |
