IndirectAbsorptionChiller ExampleFile - Generator Heat Input Correction Function of Condenser Temperature Curve used in the example file downloaded from EnergyPlus website show a reduction of the generator heat input with increasing of condenser entering water temperature despite I expect a growing trend with increasing of these temperature. The coefficients of the cubic curve are correct? There are any reference database for such curves? Thanking you in advance. All the best
