Dear all I have been facing this error on Euclid for Sketchup. You can test the attached file.
ERROR: RangeError 0x000107f0f05390 is not id value
BACKTRACE:
C:/Users/luca/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/euclid/lib/legacy_openstudio/sketchup/Sketchup.rb:101:in _id2ref'
C:/Users/luca/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/euclid/lib/legacy_openstudio/sketchup/Sketchup.rb:101:indrawing_interface'
C:/Users/luca/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/euclid/lib/legacy_openstudio/lib/interfaces/Zone.rb:136:in block in update_entity'
C:/Users/luca/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/euclid/lib/legacy_openstudio/lib/interfaces/Zone.rb:135:ineach'
C:/Users/luca/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/euclid/lib/legacy_openstudio/lib/interfaces/Zone.rb:135:in update_entity'
C:/Users/luca/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/euclid/lib/legacy_openstudio/lib/interfaces/DrawingInterface.rb:80:indraw_entity'
C:/Users/luca/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/euclid/lib/legacy_openstudio/lib/interfaces/ModelInterface.rb:204:in block in update_model'
C:/Users/luca/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/euclid/lib/legacy_openstudio/lib/interfaces/ModelInterface.rb:200:ineach'
C:/Users/luca/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/euclid/lib/legacy_openstudio/lib/interfaces/ModelInterface.rb:200:in each_with_index'
C:/Users/luca/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/euclid/lib/legacy_openstudio/lib/interfaces/ModelInterface.rb:200:inupdate_model'
C:/Users/luca/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/euclid/lib/legacy_openstudio/lib/interfaces/ModelInterface.rb:117:in draw_model'
C:/Users/luca/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/euclid/lib/legacy_openstudio/lib/ModelManager.rb:182:inopen_input_file'
C:/Users/luca/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/euclid/lib/legacy_openstudio/lib/ModelManager.rb:65:in attach_input_file'
C:/Users/luca/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/euclid/lib/legacy_openstudio/lib/ModelManager.rb:57:instart'
C:/Users/luca/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/euclid/lib/legacy_openstudio/lib/PluginManager.rb:141:in new_model'
C:/Users/luca/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/euclid/lib/legacy_openstudio/lib/PluginManager.rb:65:instart'
C:/Users/luca/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/euclid/lib/legacy_openstudio/lib/PluginManager.rb:218:in <module:LegacyOpenStudio>'
C:/Users/luca/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/euclid/lib/legacy_openstudio/lib/PluginManager.rb:23:in<top (required)>'="" c:="" program="" files="" sketchup="" sketch~2="" tools="" rubystdlib="" rubygems="" core_ext="" kernel_require.rb:54:in="" <code="">require'
C:/Program Files/SketchUp/SKETCH~2/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:54:inrequire'
C:/Users/luca/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/euclid/startup.rb:37:in block in <top (required)>'
SketchUp:1:incall'
CONFIGURATION: Euclid 0.9.3 SketchUp 17.2.2555 64-bit Pro Ruby 2.2.4 x64-mingw32
Any suggestions would be appreciated.
Regards Luca
