I try to use EMS module to implement the return-air-temperature-sensor-offset for OA-Mixer But I face a question: which node is the reference point for the sensor offset? Thanks.
| 1 | initial version |
OA-Mixer. (FaultModel currently has a bug)
But I face a question: which node is the reference point for the sensor offset? Thanks. Thanks.
I try to use EMS module to implement the return-air-temperature-sensor-offset for OA-Mixer. (FaultModel currently has a bug)
bug).
But I face a question: problem: which node is the reference point for the sensor offset? Thanks.
| 4 | retagged |
I try to use EMS module to implement the return-air-temperature-sensor-offset for OA-Mixer. (FaultModel currently has a bug). But I face a problem: which node is the reference point for the sensor offset? Thanks.
| 5 | retagged |
