I'm trying to set Site:WaterMainsTemperature within OpenStudio, but nothing I do is impacting the results (e.g. water heater energy usage and and Water Heater Use Side Inlet Temperature is unchanged). With prior models, I successfully used the Set Site Water Mains Temperature measure but that is not working here. I noticed that my prior .osm file had a Site:WaterMainsTemperature object, but my current model does not. Should I attempt to add that object my new .osm file via a text editor? Any other ideas?
