Hi, I read about Air to water heat pump and I Insert Heat pump water heater in Zone equipment and put water heater on heating plant loop, but after simulation I have 0 values for heating and only water use, how could I separate two results, I need to know both uses (Hot Water and Heating)?
Exist a better solution for model I need to do, explained below?
Supply side: Air to water heat pump combined with a boiler hot water, Demand side: HW coils.
