I am trying to create a semi-transparent pv to replace the window in order to study the changes of peak cooling load and electricity benefit. I have studied some paper which stated that they set the semi-transparent pv window by adding the encapsulated pv between the window.
Any method to create the semi-transparent pv?
Thank you for your help!
