Openstudio Envelope Section Error
I'm having trouble deciphering my simulation error. It appears isolated to an envelope error but I am a rookie at this.
Running Openstudio 2.3.0
Result: Success Initial Condition: Gathering data from EnergyPlus SQL file and OSM model. Final Condition: Generated report with 20 sections to ./report.html. Warn: Envelope section failed and was skipped because: Optional not initialized. Detail on error follows. Warn: C:/Users/loum/AppData/Local/Temp/OpenStudioApp.Z14684/resources/measures/OpenStudioResults/measure.rb:192:in eval' C:/Users/loum/AppData/Local/Temp/OpenStudioApp.Z14684/resources/measures/OpenStudioResults/resources/os_lib_reporting.rb:1628:inblock in envelope_section_section' C:/Users/loum/AppData/Local/Temp/OpenStudioApp.Z14684/resources/measures/OpenStudioResults/resources/os_lib_reporting.rb:1626:in each' C:/Users/loum/AppData/Local/Temp/OpenStudioApp.Z14684/resources/measures/OpenStudioResults/resources/os_lib_reporting.rb:1626:inenvelope_section_section' (eval):1:in block in run' C:/Users/loum/AppData/Local/Temp/OpenStudioApp.Z14684/resources/measures/OpenStudioResults/measure.rb:192:ineval' C:/Users/loum/AppData/Local/Temp/OpenStudioApp.Z14684/resources/measures/OpenStudioResults/measure.rb:192:in block in run' C:/Users/loum/AppData/Local/Temp/OpenStudioApp.Z14684/resources/measures/OpenStudioResults/measure.rb:187:ineach' C:/Users/loum/AppData/Local/Temp/OpenStudioApp.Z14684/resources/measures/OpenStudioResults/measure.rb:187:in run' :/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb:454:inapply_measure' :/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb:74:in block in apply_measures' :/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb:32:ineach_index' :/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb:32:in apply_measures' :/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/jobs/run_reporting_measures.rb:85:inperform' :/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/run.rb:261:in step' :/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/run.rb:210:inrun' :/openstudio_cli.rb:804:in execute' :/openstudio_cli.rb:620:inexecute' :/openstudio_cli.rb:1517:in <main>' eval:85:ineval' eval:85:in require_embedded_absolute' eval:70:inblock in require' eval:64:in each' eval:64:inrequire' eval:2:in `<main>'
2.3.0
Result: Success Initial Condition: Gathering data from EnergyPlus SQL file and OSM model. Final Condition: Generated report with 20 sections to ./report.html. Warn: Envelope section failed and was skipped because: Optional not initialized. Detail on error follows. Warn: C:/Users/loum/AppData/Local/Temp/OpenStudioApp.Z14684/resources/measures/OpenStudioResults/measure.rb:192:in eval' C:/Users/loum/AppData/Local/Temp/OpenStudioApp.Z14684/resources/measures/OpenStudioResults/resources/os_lib_reporting.rb:1628:inblock `eval' C:/Users/loum/AppData/Local/Temp/OpenStudioApp.Z14684/resources/measures/OpenStudioResults/resources/os_lib_reporting.rb:1628:in `block in envelope_section_section' C:/Users/loum/AppData/Local/Temp/OpenStudioApp.Z14684/resources/measures/OpenStudioResults/resources/os_lib_reporting.rb:1626:in each' C:/Users/loum/AppData/Local/Temp/OpenStudioApp.Z14684/resources/measures/OpenStudioResults/resources/os_lib_reporting.rb:1626:inenvelope_section_section' `each' C:/Users/loum/AppData/Local/Temp/OpenStudioApp.Z14684/resources/measures/OpenStudioResults/resources/os_lib_reporting.rb:1626:in `envelope_section_section' (eval):1:in block `block in run' C:/Users/loum/AppData/Local/Temp/OpenStudioApp.Z14684/resources/measures/OpenStudioResults/measure.rb:192:ineval' C:/Users/loum/AppData/Local/Temp/OpenStudioApp.Z14684/resources/measures/OpenStudioResults/measure.rb:192:in block `eval' C:/Users/loum/AppData/Local/Temp/OpenStudioApp.Z14684/resources/measures/OpenStudioResults/measure.rb:192:in `block in run' C:/Users/loum/AppData/Local/Temp/OpenStudioApp.Z14684/resources/measures/OpenStudioResults/measure.rb:187:ineach' C:/Users/loum/AppData/Local/Temp/OpenStudioApp.Z14684/resources/measures/OpenStudioResults/measure.rb:187:in run' :/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb:454:inapply_measure' `each' C:/Users/loum/AppData/Local/Temp/OpenStudioApp.Z14684/resources/measures/OpenStudioResults/measure.rb:187:in `run' :/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb:454:in `apply_measure' :/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb:74:in block `block in apply_measures' :/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb:32:ineach_index' :/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb:32:in apply_measures' :/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/jobs/run_reporting_measures.rb:85:inperform' `each_index' :/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/util/measure.rb:32:in `apply_measures' :/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/jobs/run_reporting_measures.rb:85:in `perform' :/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/run.rb:261:in step' :/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/run.rb:210:inrun' `step' :/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/run.rb:210:in `run' :/openstudio_cli.rb:804:in execute' :/openstudio_cli.rb:620:inexecute' `execute' :/openstudio_cli.rb:620:in `execute' :/openstudio_cli.rb:1517:in <main>' eval:85:ineval' `<main>' eval:85:in require_embedded_absolute' eval:70:inblock `eval' eval:85:in `require_embedded_absolute' eval:70:in `block in require' eval:64:in each' eval:64:in`each' eval:64:in `require' eval:2:in `<main>' require' eval:2:in `<main>'
